how many quarts in a 12 bolt
Old Apr 2, 2004 | 07:16 PM
  #16
palehorse77's Avatar
Smile
By the way, I have a TA cover. So 4.5 is perfect. Sounds like the chatter is just due to the 800 # springs which makes sense.
Old Apr 5, 2004 | 08:43 AM
  #17
steve-d's Avatar
Palehorse77,
Try reading the top of my post before you spout off.
Yes, I do drive an FBody. Yes, it has a 12 bolt. Yes, I've refilled it per my posted comments. Just restating standard & obvious procedures. Nothing different compared to what you stated but certainly not five quarts. Let's be constructive and have a little humor.
Regards
Steve
Originally posted by palehorse77
WHo ever the hell steve d is pull your head OUT. Were talking rear ends here.
You fill to the fill level of the fill plug.
Old Apr 5, 2004 | 04:06 PM
  #18
steve-d's Avatar
You fill to the fill level of the fill plug. Unless you have instructions telling you otherwise. Which I told you I didn't have.
As noted in my post there is a set procedure for changing the oil and avoiding overfilling it. Yes, I used a little humor, but only for a little levity.
Strictly for the benefit of others inserting too much oil in their Moser 12 bolts, you DON'T fill to the level of the fill plug. You fill to approx 1/16 to 1/8 inch below the level of the "overflow plug" hole. Totally different port on the rear housing.
Regards
Steve
Old Apr 5, 2004 | 11:38 PM
  #19
"FIVE Quarts!!! Look you have to know there is a specific method to drain and refill these units. Unfortunately, its extremely complicated.
First, drain old oil. Not necessary to turn the car over to get it out of the breather, just remove the drain bolt."
Look you have to know that your a f*&king idiot. I'm not refilling shi*(.
Therefore no old oil. Also Breather is locate about 10' forward in engine compartment.
Oh levity I get it turn car over no pun aHHH haaaa, thanks for the funny, yet helpful advice. Guys like you make this site what it is keep up the good work.
Folks look for more of steve-d at assclownsareus.com
Old Apr 6, 2004 | 11:41 PM
  #20
trackman's Avatar
"FIVE Quarts!!! Look you have to know ....
Palehorse77, you're an absolute horse's ****. Steve-d gave the right advice and you're an idiot for ignoring it. You obviously used the fill hole as the over flow hole. What a baffoon!! Its one thing to make a mistake, but a whole different issue to ignore a correction.
You used what? Five Quarts? Four and one-half quarts? What a Clown!
Open the overflow hole for the exact amount. Guess why Moser and Strange put the hole there? Certainly not for your pencil width third member.
Go ahead and ask your 'race" buddies where the vent hole on the 12 bolt is located. Guaranteed its not 10 feet from the rear end. Try looking at the passenger side axel tube, top portion. If you've done any racing, you'd be checking it for excesive overlow. But some how you seem all talk and I doubt you've ever seen a drag strip.
Old Apr 7, 2004 | 12:35 PM
  #21
Track man, new member or just hiding?
Old Apr 7, 2004 | 12:59 PM
  #22
steve-d's Avatar
Hey, just read the info I gave. Nothing special to get bent outa shape about. Just pointing out the use of the Over flow hole.
Steve
Old Apr 7, 2004 | 06:10 PM
  #23
Angry
Steve I do appreciate helpful input. I was looking for opinions and I got one. Now If I remember correctly your reply was a little snide. So I played back. I may need to see a shrink but I'll be ok in the end.
Hey at least it was a lively discussion -
THere are a lot of dead bbs (forums) out there, at least this isn't one of them.
All being said I'd put up with Your BS than screw my brand new 12 bolt.
Best of Luck this season ,
Old Apr 7, 2004 | 08:28 PM
  #24
AL SS590 M6's Avatar
Moderator
Originally posted by slp223
it takes 4.5 quarts with a ta cover
That would be 4.5 PINTS. 2 1/4 -1/2 of the big bottles.
Old Apr 7, 2004 | 08:48 PM
  #25
Serene's Avatar
I feel sorry for your differential assembly if you are only putting 4.5 pints in. fill until the stuff comes out the plug.
Old Apr 7, 2004 | 08:57 PM
  #26
JasonD's Avatar
Admin Emeritus
Can you guys play a little nicer?
Old Apr 7, 2004 | 09:33 PM
  #27
rskrause's Avatar
Moderator
You took dem words right outta my mouth!
Rich
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dylan1303
May 22, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
kev93z28
Aug 19, 2002 12:48 AM
