how does a gear
Old Nov 27, 2003 | 03:35 AM
FLIPPINZ28's Avatar
how does a gear
how does a gear make you faster i am going from a 3.23 to a 3.73 will i notice a diffrence in power and how much will i gain in an 1/8 mile thanks
Old Nov 27, 2003 | 09:22 AM
boomcase's Avatar
Gears do not add HP, they just get you going faster. Drive shafts turns 3.73 times to the tires 1 time of rotation. That gear change would be good for probable 1 to 2 tenths in the 1/4. I would spend my money on a torque converter and leave the 323s alone.
Old Nov 27, 2003 | 11:18 AM
FLIPPINZ28's Avatar
how much time is a tc good for like a 2500 stall
Old Nov 29, 2003 | 06:17 PM
unvc92camarors's Avatar
about .5 or so
results may vary
Old Dec 1, 2003 | 10:27 PM
JohnOConghaile's Avatar
[[B]Gears do not add HP, they just get you going faster. }
Now.....really this isnt true technically. Gearing down (higher numerically) increases torque, any time you have an effect on torque you effect horsepower since horsepower is a number which is a derivative of power (torque) over an amount of time or speed.
Old Dec 2, 2003 | 04:57 PM
OldSStroker's Avatar
Re: how does a gear
More gear multiplies torque to the rear axle (tires). Torque to the tires is what accelerates your car. Well, actually torque divided by the tire's rolling radius to get a force at the tire contact patch. Force accelerates just about anything. F=ma
Example: 400 lb-ft torque at the flywheel x 3.00 trans ratio x 3.23 axle ratio = 3876 lb-ft at axle (with friction losses neglected for simplicity). Assume 12-3/4 inch rolling radius or 12.75/12 = 1.063 ft, you have 3876/1.063 or 3646 lbs of force at the tire patchs. Let's say your loaded up car weighs exactly 3646 lbs. That should geive you 1.00 g acceleration at that point if you have perfect traction, and no drag. (Simplified example, remember. )
Same conditions except 3.73 gear: 400 x 3.00 x 3.73 = 4476/1.06 or 4211 lbs. now 4211/3636 = 1.15 g's. or about a 15% increase.
That's the same ratio as 3.73/3.23.
Horsepower to the tires really doesn't change because the same gears that increase the torque decrease the rpm. Do the hp numbers at the rear wheels if you wish.
Now a lot more enters into acceleration performance, so you won't be 15% quicker. If you have adequate traction your 60 time might be better. Shift points will change and you might need one more shift in the 1/8th. That will cost you time, so there might be a couple of tenths or maybe not. "results may vary" is a very good comment. BTW, your speed in the 1/8th probably won't change much at all.
My $.02
Old Dec 3, 2003 | 08:28 AM
Re: Re: Re: how does a gear
Originally posted by TreyM
not highly opinionated any more?
Always!
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
