How to convert a 3 channel to a 4 channel
Old Sep 5, 2007 | 11:31 AM
Wicked 97TA's Avatar
Does anyone know how I can convert a 3 channel LT1 rearend to a 4 channel rearend?
Old Sep 5, 2007 | 11:43 AM
Zepher's Avatar
more work than it's worth, unless you are adding traction control (which is the reason for 4 channel).
If you are asking about just installing a 3 channel rear on a 4 channel car, all you need to do is add reluctor rings to each axle (or install 4ch axles) and mount the 4ch backing plates (they have holes for the sensors).
Old Sep 5, 2007 | 11:45 AM
Off the top of my head, I would say you would need to change axles, add the sensors at each axle and the accompanying wiring.
Old Sep 5, 2007 | 02:18 PM
The deal with my car is it was wrecked before I had it and it needed a new rearend. The pervious owner put a rearend out of an LT1 car in it and now my ABS on the rear wheels and TCS don't work. I'm going to pick up the damaged rearend from the car tonight so what will I need to switch to the LT1 rear to make everything work?
Old Sep 5, 2007 | 02:23 PM
Zepher's Avatar
Edit: what is damaged on the original rear?
Old Sep 5, 2007 | 03:09 PM
Not that I know of, I'll know more when I go pick it up.
Old Sep 5, 2007 | 07:30 PM
I've got the rearend now and all that was damaged was the panhard mount was bent, everything else is fine. What all do I need to take off to convert my rear to 4 channel?
2QUIK6
Sep 17, 2016 02:31 PM
jbert55
Oct 31, 2015 03:52 PM
Aug 5, 2015 08:35 AM
jbert55
Aug 3, 2015 05:49 PM
detroitmuscle
Jul 31, 2015 04:21 AM
