help with rpm
Old Dec 4, 2010 | 08:38 PM
sk101400's Avatar
help with rpm
i have a question about rpm
my 94 z-28 is running 2000 rpm at 65 mph does this sound right seems high to me
i have 3.23 stock gears i am thinking.
anybody have idea if this sounds right?
Old Dec 4, 2010 | 09:30 PM
Re: help with rpm
A 4L60E (assuming that's what you have -since only the A4's have 3.23 gears), in O/D, with stock tire diameter (25.7 - 26.2" - but you didn't mention what tires you are running)) and a 3.23 rear axle will turn 1,875 RPM (26.2" tire) RPM to 1,911 RPM (25.7" tire) at 65 MPH. The stock tach typically reads 100-200 RPM higher than the true RPM. You can get the true RPM be reading the PCM with a scanner.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
