HELP pilot bearing
Old Aug 27, 2005 | 04:29 PM
  #31
ZMAN Z28's Avatar
Re: HELP pilot bearing
Originally Posted by Shimaze
Yes, the toilet paper thing is for real! I did it a couple of years ago & it worked great. It is the same idea as grease, but without the greasy mess. Unless you use used toilet paper ...which I don't recommend!
Just flip the toilet paper over. Kinda like the second week of underwear. Inside out. You're good to go.
Old Aug 27, 2005 | 06:17 PM
  #32
wrd1972's Avatar
Hammer in some soaking wet toilet paper in the hole of the pilot bearing, it will hydraulically force the bearing out. Sounds wierd but it works everytime, I have even seen pros do this if they dont have a puller. I have done it 3 time on my car without failure. You will be surprised how much TP will go in there too.
Old Aug 28, 2005 | 07:22 AM
  #33
Shimaze's Avatar
Arrow Re: HELP pilot bearing
He already tried the normal methods as you suggested. He obviously had a very unusual problem. Meccadeth, I am some how feeling your pain . You must have a very good neighbor. So, how many times do you have to cut his grass for free?
Old Aug 28, 2005 | 10:59 AM
  #34
Josh'95Z28conv's Avatar
Originally Posted by 96TurboTA
I think that was the problem. The tips you've been given work better on a pilot bushing. That thing looks like a pilot "bearing". I'd ditch that new bearing and put in a bushing instead.
I cant understand why everyone says this. Bushings wear, bearings dont. A bearing could fail, but how many have you seen do that? When I pulled my bushing after 15k miles, it was pretty wore out. That may have been what took out my clutch so early. I will never use a bushing again. A bearing is the way to go.
Old Aug 28, 2005 | 01:40 PM
  #35
Meccadeth's Avatar
I bought him beer instead. 48 Michelobs sounds like a fair trade doesn't it?
Old Aug 31, 2005 | 11:17 PM
  #36
QUASARBLUEZ28's Avatar
Bushing wear, but bearings grenade.
Old Sep 1, 2005 | 03:08 PM
  #37
96TurboTA's Avatar
Exactly. Bushings have been used for over 40years because they work.
Old Sep 1, 2005 | 03:18 PM
  #38
Z95m6's Avatar
A bushing will survive much better with out grease. As soon as that bearing runs dry you are SOL. I put a bushing back in mine.
Old Sep 1, 2005 | 05:55 PM
  #39
How many bearings have you seen grenade? Ive seen none. How many bushings have you seen wore the **** out? I cant count how many Ive seen like that. JMHO
Old Sep 1, 2005 | 06:04 PM
  #40
Z95m6's Avatar
I haven't seen any quote "grenade" but i've seen an awful lot of bearings with no guts in them at all because they got dry and came apart. I've seen people on here say their bearings have gone bad and tore up their input shaft. At least on a bushing the bushing takes the wear not the input shaft.
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
