Help With Getting C-Clip Off
Old Dec 1, 2003 | 10:35 PM
2FNFAST's Avatar
Decide tonite I would try and replace my rear axle shaft but I cant seem to get the c clip off the end of the axle shaft. It is a non traction control car and has discs. I can see the c clip just fine but the springs for the posi seem to be in the way? Its a 96 Z also if it helps. Thanks
Old Dec 2, 2003 | 06:47 AM
IDOXLR8's Avatar
Make sure you push the axle as far into the housing as possible. Did you rememeber to remove the pin from the diff? The easiest way to remove the c-clips is with a magnet.
Old Dec 2, 2003 | 09:51 AM
2FNFAST's Avatar
But I can barely even see the C Clip much less grab it, but my axle does not slide in very far.
Old Dec 3, 2003 | 06:51 AM
IDOXLR8's Avatar
Did you remove the pin from the differential? I think it is a 7mm bolt that secures the pin in the diff.
Old Dec 3, 2003 | 07:11 PM
Dannno's Avatar
Also, you'll need to remove the ABS pickup. Its a magnet at each hub secured by one bolt. As you push your axles in, thats the first thing it hits.
kevm14
Aug 2, 2006 10:17 PM
69gto96z
10
Mar 28, 2006 12:46 AM
maksik7
Jun 16, 2005 03:52 PM
VILeninDM
Jan 26, 2005 11:41 AM
kmanRS/SS
Classic Engine Tech
Nov 5, 2003 09:01 PM
