Heeeeelllllpppp!!!!!!
Old Dec 3, 2003 | 12:50 PM
Heatmaker's Avatar
Advanced Member
Exclamation Heeeeelllllpppp!!!!!!
Ok I just got the Bearings on the Differential now. But how far should they be on there? There's a little gap between the Bearing and the Differential. Right now I have the Bearing on there flush with the Tip of the Differential. Should it be all the way seated on there closing the gap or am I fine with keeping it flush?
Old Dec 3, 2003 | 09:08 PM
Heatmaker's Avatar
Advanced Member
ttt
Old Dec 3, 2003 | 09:42 PM
Brandon 95 Z28's Avatar
This seems like the longest gear install in history, lol. They should be pretty well on there, but its hard to say if yours are on there right without a pic. You'll know they arent on far enough when you put the races on,and then you try to put the diff back in, and you are at 0 backlash with no shims
Brandon
