Help- Gear Install Problems
Old May 16, 2007 | 06:30 PM
CamaroSS8887's Avatar
So I have everything put back together except for the little springs in the posi unit. I took them off to get the c clips out and now that everything is back together i can't figure out how to put the springs back in. I tried everything, even compressing them with wire. So any answers would be apreciated. and it a series carrier if that makesa difference.
Old May 16, 2007 | 06:44 PM
so i just found out all i had so i didn't have to take the springs off was remove the traction control sensor and slip the c clips off but too late now and still help
Old May 16, 2007 | 06:48 PM
Capn Pete's Avatar
Oh man!!! What did you do THAT for?!?!?!?!?! If you haven't realized this yet, you don't need to pull the carrier apart to get the C clips in/out! All you do is pull the large "pin" that goes through the carrier (which is held in with a small bolt off to one side) and then push the axles in as far as they go ... the clips almost fall out, you just need a magnet to grab them. You can re-install them by hand.
Well, now onto your problem! Can you not compress those springs tight enough with a pair of needle-nose pliers or something?? You're just gonna have to keep fighting with them ... get one end up in place, and maybe use a large flat-blade screwdriver, or a flat scraper or something, and pry the other end into place . I watched my Dad pull an Auburn apart and reassemble it, but that was a couple years ago, so I don't remember exactly how hard it was to get those springs out and back in??
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
Noenav
Dec 6, 2014 07:35 PM
slothgrant
Aug 22, 2002 03:01 PM
