help!
if there is some sticking out of the trans you can try to get it out with a pair of vise grips
if not you can try to work it out with a punch
if not then it needs to be drilled out and use an easy out
you might want to seriously consider taking this to a shop and letting them take care of this for you, it may cost you a few bucks but you will be saving yourself a considerable amount of headache, and possible damage if you screw up drilling it out
I had this happen to me on a different car (and it wasnt a tranny mount bolt, it was a manifold header bolt, what i did was take a drill bit that is lttle less than half the diameter of the bolt, i drilled into it slowly and was able to get the bit to grab and start turning the bolt after that i took the drill of the bit and then got some pliers and started turning till i was able to completely walk the bolt out. you may not have my lock, but it could work, just take you time and think of all possible options before you attempt to remove it. GOOD LUCK
