Grinding Noise From Rear End..Help
Old May 26, 2005 | 10:11 AM
96HealyZ28's Avatar
Ok, so I'm driving to the store yesterday and I have my windows up and air conditioner pumping and I start to hear what almost sounds like one of my pipes dragging on the ground... but not quite as loud as that would be. I park at the store and check to see if something is hitting the ground, nothing... and I check my brake pads, they are fine. So when I leave the store, I roll down my window and keep the A/C off to hear better and sure enough, a hollow grinding noise is coming from the back of my car. It sounds the worse when I am coming to a stop, kinda like gears grinding to a halt, but you can still hear it while driving slowly. I'm thinkin' my rear end went out. Tell me what you think. Also, if you know, how much this will set me back if it is the rear end. Thanks for your time.
Old May 26, 2005 | 10:44 AM
BUBBA's Avatar
Re: Grinding Noise From Rear End..Help
I'd have my brakes checked before assuming it is the gears. Just because you"checked" the pads doesn't necessarily mean everything is good. JMHO
Old May 26, 2005 | 10:49 AM
96HealyZ28's Avatar
Thanks for the advice, I will have them checked out this weekend thoroughly... did I spell that right?? lol
akwa
Apr 5, 2015 05:09 PM
BigWil
Mar 29, 2015 12:24 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
thenewkid
Nov 27, 2014 09:41 AM
squarehead
Nov 21, 2014 08:02 PM
