BIZARRE clutch problem T56
Old May 25, 2005 | 10:30 AM
kroqz28gto's Avatar
Here we go again, new clutch, freshly cut flywheel with shim installed, new pilot, about an inch or two from the floor the metal on metal grinding noise starts. I've read previous posts that this could be the shift fork hitting the pressure plate. The clutch appears to be working, but the noise. Could the fork be bent causing the problem? Can the fork be removed with the trans in place? Anyone ever pushed it though and back out the front where the bell housing cover goes?
Old May 25, 2005 | 12:04 PM
96TurboTA's Avatar
Re: BIZARRE clutch problem T56
The shift fork is cast iron, so I doubt it's bent. You'll have to pull the tranny to get the fork out.
Old May 26, 2005 | 11:28 AM
1996camarors's Avatar
Ok I might know what it is.
Does it do it only when cold?
It might be your pilot bearing
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
