GM stock 10 bolt
Old Jul 17, 2006 | 03:17 AM
crushah's Avatar
GM stock 10 bolt
getting ready to order 4:10's, does anybody know if the stock
10 bolt is a 7.5 or 8.5 in. also does the spline count matter, i counted
for 41....some places have told me it doesn't matter. i figured
it do matter. any help is greatly appreciated.
Old Jul 17, 2006 | 03:40 AM
angel71rs's Avatar
Re: GM stock 10 bolt
What year? Also what ratio is currently in there? The series of the posi carrier will play a part in which gears to buy.
Old Jul 17, 2006 | 06:47 AM
87DJP2001's Avatar
Another rear gear ratio change by someone who dosent know what they are doing.
Old Jul 17, 2006 | 07:01 AM
MyShibbyZ28's Avatar
The 10 bolt in camaros are 7.5/7.625", and spline count of what? The pinion? I don't know what spline count you got 41 from, but the pinion is 27 I believe. Posi series will tell you exactly which gears to buy. Also, you will want the car retuned sometime so the odometer, and speedometer read correctly. Otherwise the milage will be higher then what it really is, and your speed will read higher then what it really is. What kind of car is this going into, manual or auto? 4.10 can be a lot of gear for an auto on the highway. If it is a manual then it is alright.
Old Jul 17, 2006 | 07:33 AM
You can't say that without knowing the year of the car. GM used three different gear diameters in 10-bolt housings over the 36 years that the F-Bodys were manufactured.
Until he tells us the year of the car, there's no point in providing possibly faulty info.
Old Jul 17, 2006 | 09:43 AM
You have a point. I assumed it was 3rd or 4th gen. Well if it's 3rd/4th gen related, then read what I posted. If not, then ignore it.
Old Jul 17, 2006 | 11:59 PM
94Camaro_Z_28's Avatar
To add, you'll need to know if you have a series 2 or a series 3 carrier. (3rd, 4th gen). 3.08 and lower ratios are series 2, 3.23 and higher are series 3.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
maybe2fast
Mar 16, 2015 09:45 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
