getting the street twin to fully release
Old May 4, 2010 | 08:11 PM
firebirdStud's Avatar
Unhappy getting the street twin to fully release
Hello!
I have a 95 firebird (LT1 style) with the mcleod street twin clutch. I do have the mcleod adjustable master cylinder, mated to a brand new line and GM slave cylinder.
I have adjusted the pedal to the stock location from the old master cylinder, but it seems that the clutch isn't fully disengaging when I put in the clutch. I say this because with the clutch fully pushed in, and shifting into any gear, the tranny clunks, the gears feel notchy, and you can feel the car try to move forward just a bit.
Which way do I start to adjust the pedal? I have heard that the rod should be shortened, but this seems counter-intuitive.
Many thanks!
Cody
Old May 4, 2010 | 09:34 PM
The more info, the better, right?
I just checked, and my clutch pedal looks to be slightly higher then the brake pedal. Dont know if that makes a difference or not. When I set it up, this was where the stock master made the clutch pedal sit...
Old May 5, 2010 | 06:18 PM
nobody knows? There are lots of people running this setup, could someone please just let me know how you adjusted it? I dont want to prematurely wear out the clutch or the syncros...
Old May 6, 2010 | 08:07 PM
I ended up shortening the rod. I put the rear on jackstands, put the clutch in, put it in first, kept the clutch in, and reved her to 6500 rpms, and the tires didn't move. Looks like she is finally fully releasing. The tires wanted to move just a little bit at 6000 rpms, but nothing too bad. They turned about an 1/8th of a revolution. Good to go!
Ringmaster72
Mar 19, 2015 03:32 PM
BPS
9
Mar 5, 2015 10:51 PM
Ringmaster72
Feb 25, 2015 03:15 PM
Nostang 96z
Sep 15, 2002 10:15 PM
RichJ
Aug 11, 2002 10:14 PM
