getting ready to do t56 swap. resurface/balance flywheel?
Old Jun 12, 2005 | 08:09 PM
sabre81's Avatar
getting ready to do the a4 to m6 swap and im wondering if its necessary to resurface the flywheel and/or get it balanced? It is a stock flywheel and will be mated with a stock clutch in new condition. yes i know its preferred that i replace the clutch and flywheel at the time of the conversion, but im going to save that for when i do heads/cam. So if the flywheel looks to be in good condition, does it need to be resurfaced or balanced?
thanks
Old Jun 12, 2005 | 08:55 PM
SantaCruz163's Avatar
Re: getting ready to do t56 swap. resurface/balance flywheel?
Chances are the flywheel doesn't need to me balanced, but it couldn't hurt. I would definitely have it resurfaced though. It's cheap enough and should always be done when installing a new clutch. Hope that helps.
Old Jun 12, 2005 | 10:04 PM
madwolf's Avatar
I would resurface it either way ($30) unless it's smooth and nice. Also check the thickness and shim if necessary. Thickness of stock flywheel should be 1.828" from surface to back.
karpetcm
Aug 14, 2015 03:02 PM
zFrank
Aug 12, 2015 03:46 AM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 24, 2015 10:47 AM
Highlanderrtl
Jul 24, 2015 03:34 AM
