how to put a 95 trans in 94??
Old Jun 12, 2005 | 12:21 PM
LT1TAGT's Avatar
I need to know how to put a 95 trans in a 94 trans am...Someone said I need to add a wire from the trans to the computer...Anyone know what wire gose where Any help would be great TIA
Old Jun 12, 2005 | 07:45 PM
sabre81's Avatar
Re: how to put a 95 trans in 94??
not that i know of. i could be wrong..
Old Jun 12, 2005 | 10:11 PM
jay_lt4's Avatar
yes the wiring is different and the pcm needs to be programmed with a 95 bin file
Old Jun 12, 2005 | 10:32 PM
madwolf's Avatar
On top of programming, you will need to run one wire from the PCM to the tranny connector.
Go to shoebox's website here and click 4L60E on the bottom. The wire on the tranny side connector will go into cavity U. (see 95)
The other end of that wire will end on your PCM's blue connector.
You can see the diagram here. The wire is labeled D6.
Old Jun 12, 2005 | 11:02 PM
LT1TAGT's Avatar
Thank you madwolf, that is what I needed to know.... Thanks for your help
PCLZ28
Dec 24, 2015 05:19 PM
SinisterRacing1
Mar 7, 2015 03:44 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jan 5, 2015 07:14 PM
Lederman1976
Nov 30, 2014 05:21 AM
