To get gears or not to get gears, that is the question
Old May 16, 2006 | 12:26 PM
93redBirdMan's Avatar
Right now my rearend has 3.23 gears. I know that 3.73 gears WILL help me, BUT I don't want to sacrafice too much strength either. I dead hook with my drag radials and that puts a lot of stress on those gears. How much strength would I be losing by going from 3.23 to 3.73. Also, it's going to cost about 800 dollars here for legit parts/install from a reputable shop...
Old May 16, 2006 | 12:29 PM
Re: To get gears or not to get gears, that is the question
Also, the rear was rebuilt in January with new posi, gears, etc. The guy that had the car at the time wasnt bright enough to go with at least 3.42s... grrr
Old May 16, 2006 | 01:23 PM
Kredz28's Avatar
I broke my 10 bolt on 275/35ZR 18's....on street tires...with 3.23's...if you go with a 3.73, you will be adding stress to those gears, especially with dr's...if you run at the track often on sticky tires, your 10 bolt will break eventually..if on street tires, they should work ok for a while.
Old May 16, 2006 | 11:56 PM
Pfeiffer Performance's Avatar
I would not be too concerned about the strength difference between 3.23's & 3.73's. The loss in strength is nominal, especialy compared to the gain in performance. I would recommend getting the American Axle brand which is the OE manufacturer. These will be the quietest gears for your car. A good shop in Fresno is Fearless Gear.
PCLZ28
Dec 24, 2015 05:19 PM
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Feb 1, 2015 08:26 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
