gears
Old Apr 20, 2011 | 10:16 PM
muddjar's Avatar
gears
how can u tell what gears you have
Old Apr 20, 2011 | 10:22 PM
dennis5374's Avatar
Re: gears
Lol not sure without taking the cover off the rear and looking. My car has 4.10s through an a4 and it reads 80 at 60 lol 2300 rpms
Old Apr 20, 2011 | 10:39 PM
muddjar's Avatar
Re: gears
after u take the cover off how will u no
Old Apr 20, 2011 | 10:45 PM
Bykerboy869's Avatar
Re: gears
http://shbox.com/1/gear_ratio.jpg
that should help you and what car you got. year, model, auto or standard? is the rear stock?
Old Apr 20, 2011 | 11:06 PM
Re: gears
Not an "engine" question. Moving to "Drivetrain".
Old Apr 20, 2011 | 11:44 PM
rbaksi's Avatar
Re: gears
If it is stock gears, look at the RPO codes. GU2 = 2.73, GU5 = 3.23, and GU6 = 3.42
Old Apr 20, 2011 | 11:48 PM
Re: gears
Might want to add specific info about your car (a "Signature"), like year, model, engine, trans and any major mods. Make is easier for people to help you.
Old Apr 23, 2011 | 09:08 AM
muddjar's Avatar
Re: gears
i have a 95 Z28 auto trans stock gears
Old Apr 23, 2011 | 09:09 AM
muddjar's Avatar
Re: gears
where r the rpo codes located
Old Apr 23, 2011 | 11:07 AM
pgerst's Avatar
Re: gears
glove box door or the build sheet if you have it.
Old Apr 23, 2011 | 12:20 PM
Re: gears
If you don't want to do any of that, jack up the rear and count the rotations of the driveshaft as you rotate the wheel one turn (ex. 2-3/4 turns of the driveshaft would be 2.73s). With stock gears and auto, will have either 2.73s or 3.23s. If you have first gear selectable on your shifter, then it came with 3.23s. If it only starts with "2", then it came with 2.73s. You can also use an online gear/RPM calculator to figure it out.
http://www.f-body.org/gears/
Old Apr 23, 2011 | 08:36 PM
muddjar's Avatar
Re: gears
thanks i guess i have 2.73s.how hard is it to put some 3.73s in and will i need to buy a programer to fix my speedo
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
