gears
Old Apr 1, 2008 | 11:34 PM
chevycamaro210's Avatar
gears
hey everyone i just wanted to ask if anyone knew what size gears does a 1997 3.8 camaro have. because i wanted to upgrade mine what size do you think would go good for a street car but will make a good upgrade
Old Apr 1, 2008 | 11:40 PM
bombebomb's Avatar
Not sure on the 3.8 but the z28's have automatic- 2.73, 3.23, manual 3.42's.
Old Apr 1, 2008 | 11:43 PM
bombebomb's Avatar
http://vlane.com/specifications/1997...specifications 3.23's, no idea on a good gear for a v6 on the street.
EDIT: sorry for double post, for some reason my thread never appeard.
Old Apr 2, 2008 | 12:49 AM
well i posted another bulletin and they told me to check my rpo codes on my door and it said gu5 which is 3.23's i know its the right rpo code cause the vin number they told me 3.73' would be best at work. But i want more opinions and how hard do you think it is to change them out.
Old Apr 2, 2008 | 04:00 AM
Green96Z's Avatar
Well I'm really not sure for gears as it's a V6. Do you just feel like you're not quick enough (I mean, it is a V6 ) but gears can be expensive. And if you've never done them before, I would NOT do a gears install, at least not alone. If not set up right, you can tear up your new gears real quick. And to install them can cost quite a bit. I think your cash could be spent on something better for your car, just my $0.02.
Old Apr 2, 2008 | 04:39 AM
rskrause's Avatar
Moderator
Almost inevitably it will whine like a little bitch after you change the ring and pinion. It requires a lot of skill and patience to install and set up a rear end properly. Almost no one has the time or skill to do it right.
Rich
Old Apr 2, 2008 | 06:57 AM
It also takes a dial indicator (plus knowledge of how to use it) and a press.
Old Apr 2, 2008 | 01:06 PM
well i work at autozone and one of the guys that work with me is a mechanic he said he would put them in for a $100
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
