gears
Old Jan 9, 2006 | 08:12 PM
gluemaker's Avatar
gears
I have a stock 02 z/28 and am looking for information on what would need to be changed if I were to change from 2.73 to 3.42
Old Jan 10, 2006 | 08:41 AM
Re: gears
You need a new carrier (3-series, in place of the 2-series that came with your car), new gears (you can get thicke 3.42r gears that will fit the 2-series carrier), and an install kit with, bearings, shims, crush sleeve, seals, gasket, lube and limited slip additive. Might want to throw in an aluminum rear cover with pre-load bolts for the bearing caps. Then you need to get your PCM programmed for the new gear ratio.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
