Gear swap
Old Apr 28, 2011 | 07:49 AM
Z26's Avatar
Z26
Gear swap
I was able to pick up a rear end from a 96 Firebird and swap it into my car, no problem. After driving it around for a week and thankfully not seeing any leaks, I changed the fluid. I was told the gears were 3.23:1, which was what I had in my old rear end. You can probably already tell where this is going. Stamped on the gears in the new rear was 41:15, or 2.73:1. What do I need to do to get the gear ration back to the original 3.23? Can I swap out the gear on the carrier?
Old Apr 28, 2011 | 04:42 PM
Re: Gear swap
Problem is you now have a 2-series carrier for the 2.73 gears. To upgrade to a 3.23 ring and pinion, you will either need to swap in a 3-series carrier, or use a thicker 3.23 ring gear to fit into the 2-series carrier. What was wrong with the old rear axle assembly? You have all the parts.
Old May 1, 2011 | 05:19 PM
Z26's Avatar
Z26
Re: Gear swap
The problem with the old assembly was the pinion bearing was messed up. Much rather than take everything apart, I just swapped in a new assembly. Now it seems that trying to avoid that is a futile effort.
Old May 1, 2011 | 11:25 PM
Re: Gear swap
You have to check the ratio BEFORE you pay for it and take it home and install it.
Old May 3, 2011 | 07:27 AM
Z26's Avatar
Z26
Re: Gear swap
Yes, yes, yes. Lesson learned. Back to the topic at hand; I'm assuming I need to pick up a new ring and pinion, because the old ring isn't thick enough, or can I reuse the old ones and space it out? Is it a fitment issue, or a placement issue?
Old Jun 13, 2011 | 11:34 AM
Z26's Avatar
Z26
Re: Gear swap
Potentially stupid question, but would it be possible to take the limited slip components out a a series two carrier and swap them into a series three? Series three carriers are found easily enough at the junk yard, but they are all open diffs and I like having the limited slip.
Old Jun 14, 2011 | 08:54 AM
dragontau313's Avatar
Re: Gear swap
no, an open carrier can not be converted into a limited slip. You can buy a series 3 limited slip for about 400 or so, or you can just buy series 2 3.73 from jegs for 205 http://www.jegs.com/i/Richmond+Gear/...007-1/10002/-1.
Old Jun 21, 2011 | 07:37 AM
Z26's Avatar
Z26
Re: Gear swap
Ok, thanks for the help.
Zee man
Feb 12, 2015 07:07 AM
rocketman051894
Jan 30, 2015 03:23 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
