Gear Install
Gear Install
I went to a local transmission shop to ask about installing a set of 3.73 gears into my 2.73 car. They said it would cost around 1000 -1200 bucks. Seems way too high. Anyone know of shop in the Pittsburgh area that would do the gear install for me? Or, what is a good way to find a shop that does gear installs?
haha, they are nuts! I paid $250 installed for mine, and that was including the gm limited slip additive. I'm sure someone will know of a good shop for you to go to. Try posting in the north eastern regional area as well. http://web.camaross.com/forums/forumdisplay.php?f=30
I installed my own gears. Its a pain. Took about 6 hours b/c it was my first time. My brother back in the day's got some installed in his 96Z and he payed like $210. So I dont know where $1000 would go. Make sure you get a Master Bearing kit. Its worth it. Richmond has them in Summit for the 10 bolt.
Huh
, a shop near me charges $400 CDN$ for a gear swap. If the shop KNOWS what they're doing, it shouldn't take that long, and they shouldn't be charging ~$1000
. Don't go to that shop!!!
you went to a transmission shop for a gear install..... its possible they dont want the job and quoted high due to the aggrivation of doing the job. Take it to a shop that does this kind of work. I would recommend most performance shops.
I've called all around and the cheapest I've found was over $450. They weren't the most renowned place around either. The quality shops were asking between $600 and $800. I'm still debating whether it's worth it or if the money should be put towards a 12 bolt or Dana.
Don't skimp out on a cheap place because it is a exact process and if it's not set right you won't last long.
...... while you don't want your gears setup WRONG, for someone who does it on a semi-regular basis, it shouldn't be a big deal, and they're only ripping you off if they're charging over ~$500
.If you're not prepared to do it yourself, and/or you can't find someone GOOD, but who will do it for a FAIR price, it just doesn't seem worth the ~$1000, when, like a couple guys are saying, you can find a used 12-bolt for that price!!!
I mean, what happens when you spend ~$1000 on your 10-bolt, to have a "reputable shop" do the job, and the gears bust ~2 weeks later anyways??????
Bet that'll be a nice kick in the *****?
Playing with 10-bolts is like playing with fire ... sooner or later you may get burned, but it's not worth PAYING someone to "burn" you knowingly
I know this post is a lil old, I just broke my Moser 12 bolt, the tru trac diff to be exact, I wanted to switch gears.... so
its nearly 500 for a new diff
155 for gears
100 for install kit
20-30 in shop meterial and fluids
5 hours shop labor @ 75/hr
6% CT sales tax
im coming close to like 1250-1300 bucks, but if the diff didnt break 700-800 is bout the norm.
155 for gears
100 for install kit
6% CT sales tax
Blackrat,
Do you still need gears installed...I just got mine done about a month ago in Santa Clara. $550 including gears, labor, fluids, etc. Reputable place..a lot of folks around here have gone there.
Greg94Z,
$1000 is way too much. Gears are only $240 or so. If you find a shop that specializes in rearends, they could do the job with 1 guy in 2 hours...so add another 2 x $100/hr...you looking close to $450-$500.
Shop around some more. But yes, find a "rearend" specific shop. They have all the tools and can do them quickly. For my car, they did my car during some downtime when they were waiting for front/rear axles for a 4x4. With 3 people, it took them 1/2 hour.
Greg94Z,
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jul 4, 2005 05:00 PM
