Best clutch + Pres. Plate???
Old May 8, 2005 | 11:57 PM
RPWS6's Avatar
I will be doing a cam and mild head swap over next winter. It will probably be somewhere between a hotcam and a LE2 package. Before I get to that point I think I want to do a clutch and pressure plate install soon, as my stock 75k setup is feeling like some slipage is going on. What is the best setup to go with? I am looking for reliability and longivity as well. Is there anything else that I should do at the same time? Also, should I do anything to my flywheel at the same time??? Thanks
Old May 10, 2005 | 09:57 PM
RPWS6's Avatar
Re: Best clutch + Pres. Plate???
anyone???
Old May 10, 2005 | 10:39 PM
roguedriver's Avatar
McLeod Street Twin. A bit more money then most, but will hold a ton of power and last. I'm sure you'll get more responses. Hard on the rear end though, so you might want to look at upgrading the rear too.
Ken R.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
