Flywheel Installtion Question
Today I will be putting my new clutch and flywheel in. I know that I have to tighten the pressure plate bolts to 22 ft lbs, and the flywheel bolts to 74 ft lbs. Is there a specific bolt pattern that I need to follow when installing the flywheel bolts? Should red loctite be used on the flywheel bolts?
