Flexplate
Old May 11, 2005 | 09:18 AM
RICEFEDZ28's Avatar
Flexplate
I've Cracked 3 So Far. Who Makes A Thick Strong Plate? 2 Were Stock 1 Was A Tci.
Old May 11, 2005 | 11:12 AM
madwolf's Avatar
Re: Flexplate
Might want to specify your application and how much power you're making.
Old May 11, 2005 | 11:24 AM
RICEFEDZ28's Avatar
Re: Flexplate
I Have A Comp Cam .510 Lift, Hooker Longtubes, Slp Loud Mouth B&m 2400 Stall, 3.73 Gear, 1.6 Roller Rockers, And All The Bolt On Stuff. It's A Daily Driver.
Old May 11, 2005 | 11:27 AM
madwolf's Avatar
Re: Flexplate
You shouldn't be braking even a stock flexplate with that. Where/how exactly does it crack? Something is out of balance or not installed properly.
Old May 11, 2005 | 11:29 AM
RICEFEDZ28's Avatar
Re: Flexplate
It Cracks All The Way Around The Bolt Holes Where It Bolt To The Crank.
Old May 11, 2005 | 11:36 AM
madwolf's Avatar
Re: Flexplate
Are the crank bolts torqued to specifications? I think they are 22 lb/ft or something.
Old May 11, 2005 | 11:42 AM
RICEFEDZ28's Avatar
Re: Flexplate
Yes
Old May 11, 2005 | 01:39 PM
Re: Flexplate
Should not be breaking. Could be a sign of the tranny not correctly aligned with the crankshaft. The plate flexs as it rotates, fatigues, and starts to crack.
My B&M SFI flex plate holds 800HP with nitrous off the line. I've seen them handle well over 1,000HP.
Old May 11, 2005 | 03:01 PM
RICEFEDZ28's Avatar
Re: Flexplate
How Do I Check The Alignment?
RUENUF
Mar 13, 2016 03:37 PM
alphaauto
Jul 26, 2015 04:40 PM
vodoo-chile
Nov 13, 2003 01:31 PM
vodoo-chile
Nov 11, 2003 08:56 AM
Nostang 96z
Sep 15, 2002 10:15 PM
