First question on this site:
Hi new im the new guy here!
First question on here: I have a 93 camaro z28 and its automatic. Well im wanting a 6spd manual is it possible to switch the transmission? How much would this cost? Has anyone done that conversion on here? Would like to replace the automatic transmission with a brand new 6spd transmission that would be original to that year or so. Would this effect my car in any way? Oh the car is pretty new also it has 37,800 original miles. And i wont sell it. I love it i was just wondering if there was a way to make it 6spd.
thanks
thanks
First off- this belongs in drivetrain...
Second- converting your car from auto to 6 speed is going to take a good chunk of change- can be done though-
Here is what you need- tranny, crossmember, pedal assembly, master and slave cyc's, flywheel, clutch assembly, shifter, center console...and I'm sure a couple other things.
Look into how much its going to cost you- bet you reconsider it when you find out how much time and money its going to cost you...
ok well i just finished my conversion and i decided that ill atempt a write up on it. I did not plan on doing a write up so i dont have as many pictures as i would like but i will try my best at making this write up better than any of the others out there. overall it wasnt very hard, but it wasnt very easy either. Just plan ahead, what could go wrong, probably will.
parts needed:
tranny /w bellhousing
clutch flywheel preasure plate
clutch master cylinder /w clutch reservior
slave cylinder /w throw out bearing
pilot bearing
shifter
shift ****
center console insert
leather shift boot
lower shift boot
vss if tranny doesnt come with one
t-5 torque arm bracket/mount
t5 cross member
clutch pedal assm
new pcm or a pcm reflash
lots of new bolts
reverse lights switch /w leads
clutch safty switch /w pigtail leads
rec new tranny mount
wire connectors
small amount of extra wire
more pictures to come when i get my camera back from my stupid sister.
1. First of course you will need to get the car up on jacks, the higher the better. Also disconnect the battery just in case.
2. Once the car is jacked up you will need to take off the torque arm, followed by the driveshaft.
To remove the torque arm there are 2 long bolts with nuts on each end located on the rearend. after removing these, remove the torque arm bracket attached to the trans. Just follow the torque arm to where it connects to the tans and you will see it, Should remove with 2-3 bolts. Next there are 4 bolts attaching the driveshaft to the rear end. Remove these and the driveshaft should pull out from the trans.
3. Next you will need to remove the actual trans from the engine, this is the fun part. Start inside the car and remove the center console. Put the car in first, there is a staple holding the shift **** on. Take a small flat head screw driver and take it out and remove the ****. Next there are 2 7mm bolts under the coin holder in the arm rest. Take those off and the shifter plate will come off. Then there are about 8 10mm bolts holding the center console in place. 2 are in the bottom of the armrest, 2 are on either side of the console (one by the cupholder and oppisite side of it), and the rest are located next to or on the shifter assm. Once the center consol is off unbolt the shifter and you can either cut the shifter cable and brake release cable or find where they are connected and disconect them. I choose to cut them and then i removed the shifter assm.
Remove all the bolts you can from the underside of the bellhousing. They are 18mm i belive. When you get to the the bolts that are too hard to reach you will need to unbolt the cross member from the car. It is located in the back and bottom of the trans. Place a jack under this so when you unbolt it the trans will not fall. There are 4 bolts each are 15mm i belive.
When you unbolt the crossmember onto the jack, you will need to slightly lower the jack. When you do this the trans will tilt back allowing you to get to the higher up bolts. The best way to get these bolts off is by using a 4 foot long extention and getting the bolts out from behind the trans.
There should also be 2 trans mounts on either side of the trans connecting the trans to the engine. For some reason my car did not have these.
When all the bolts are removed it is time to pry the tranns away from the engine. The easist way to do this i found is get a type of crowbar and stick it between the engine and the trans and push very hard. But be very carful once the trans is pushed far enough away, the trans will fall out and you DONT want it to fall on you (ITS HEAVY!!!) Also make sure all the connectors are off of the trans before letting it fall.
4. Once the trans is removed you are left with the torque converter.
there are 3 bolts holding this on if i remember correctly. But to get to the bolts you need to remove the inspection plate first. There should be at least 1very small bolt holding it in place, and then it should pull out (with some forcefull hands ) dont worry about bending it or even cutting it, you wont be using it again.
Once the inspection plate is out you can reach the bolts holding the torque converter to the flex plate. you will need to stick a screwdriver or something into the flex plate so it will not rotate when taking the bolts off. Every time you take a bolt off, you will need to rotate the torque converter to get to the next bolt. Once the verter is off, then you can unbolt the flex plate, there should be 8 bolts.
5. Once the flexplate is off you can put in your pilot bearing. Get it in there as far as you can, it should be very close to flush. After that, on goes your flywheel. Make sure it lines up right and you get all the bolts very tight. You cant use the same bolts you took out, so find new flywheel to crank bolts.
Put on the clutch disk and use the alinment tool to make sure it stays alined.
Then put on the preasure plate and try and torque the bolts in a star pattern.
6.Once all the clutch stuff is in, it's time for the clutch hydrolics (yay!)
start by removing the panel under the steering wheel
Then you can remove the brake pedal. Now this might sound easy but think again. I HIGHLY reccomend removing the drivers seat for more room. To remove the pedals there are a total of 5 bolts. 2 on either side of the steering colum and one above pedal right behind all the wire connectors that attach to the brake pedal. There are 2 push type connectors attached to the pedal, brake light switch and cruise control disengage switch. Disconnect these and unscrew them. Then the brake pedal should come out.
put the brake sensor switches back onto the new pedal assem and put the new pedals in. Make sure the sensors are screwed in the right amount, or the brake lights wont come on.
7. next you need to mount the clutch master cylinder it goes right here...
you will need to drill 2 holes and a bigger hole in the middle, i reccomend using a hole saw to do this.
it may take some some forcefull thinking to get the master cylinder in there.
and this is where the clutch reservior mounts
lead the steal braided line down to the back of the engine where the trans will be later.
8. next you will need to cut a hole for the shifter, mine is a little long but it doesnt really matter if you are off by too much. dont start as far back as i did. some trimming might need to be done later so dont worry about getting it perfect.
9. time to put the manual trany in now. but before you put it in, bolt on the slave cylinder, you will need to remove the bellhousing from the trans in order to get in on. now the trans should bolt back on the same way it came off but, you may need to improvise a little. Make sure you put on your new torque arm bracket before putting the trans in. once the new trans is in put the torque arm back on as well as the driveshaft.
10. you're not done yet, time for the wiring. There are basicly 3 things you need to wire, they are.....
you may need extentions to reach the trans and the clutch safty switch.
Hook up all the connections to the trans and make sure you connect the master cylinder line to the slave cylinder. Then add brake fluid to the clutch reservior and bleed the clutch.
11. now add tranny fluid to the trans, you need 3.4 quarts of atf. You can add it through where the shifter mounts. Then attach the shifter use some silicone rtv to seal it. followed by the lower shift boot i used self tapping screws to keep it in place. You should be able to start the car now. Start it and make sure it works. Put it in first and see if the tires rotate. Then put it in reverse and see if the reverse lights come on. Then i put the center console back togeather
12 before taking it off the stands get under the car and listen for any abnormal sounds, like knocking or scraping. If all sounds good, take the car off the stands and take it for a test drive. MAKE SURE YOU GET A METAL RETAINER SO THAT YOUR MASTER CYLINDER ROD DOES NOT POP OFF YOUR CLUTCH PEDAL.
The car is ok to drive but you will need to get your pcm reflashed soon, so dont plane on going around racing just yet.
"ALL THIS WAS POSTED ON AZFBA.COM FROM MEATYSHELLS" GIVE HIM ALL THE CREDIT...i was going to do the swap myself but i'm just gonna build my auto and give it a nice stall and shift kit!
parts needed:
pilot bearing
shifter
shift ****
leather shift boot
lower shift boot
t5 cross member
clutch pedal assm
lots of new bolts
wire connectors
Thank you so much for the info!!!!
Would it be better to have someone that can work on these to do the conversion? Doing this, it should not hurt my car in any way right? And where can i find these parts or a transmission new?
Thanks again
Thanks again
I personally like the automatic in f-bodies. It shifts nice and rough and will chirp the tires at every gear change.
My thought is that this project will likely be more trouble than it's worth.
Unless the car is something extremely rare or impossible to get, like a manual '93 Pace Car, I can't see a great reason to do this unless you intend on keeping the car for a very long time.
Look in the for sale section, there are 2 manual conversion posts floating around last I saw. Expect to spend between $1,500 and $2,000 by the time you're finished if you do the work yourself. If done properly, this won't affect your car in any negative fashion. Of course, driver error can always be a factor
Well Alan... For me, it's more trouble than it's worth.
Even changing the oil is more trouble than it's worth. I'd rather not drive the car than change the oil.
I don't like to get dirty. Changing things under the hood and inside the interior is fine with me, but getting on my back sucks.
The tranny should include the vehicle speed sensor (VSS), skip shift solenoid, reverse lockout solenoid (all on the driver's side) and the back-up light switch (passenger side). On the front of the tranny, on the cover plate, there should be a "T" bolt screwed in for the clutch fork to pivot on, and a clutch fork. On top of the tranny should be a vent hose. You also need the bolts that attach the tranny to the bell housing.
The bell-housing fills the gap between the front of the tranny and the back of the engine, and encloses the clutch. The bell housing should come with two long studs and a "cup" to mount the clutch slave cylinder. It will also have a dust cover around the area where the starter nose pokes through to engage the ring gear on the flywheel. You will need the bolts that hold the bell housing to the back of the engine.
Make sure you get a T56 from an LT1. The LS1 (98-02) has a different input shaft length and a different clutch style. They are not interchangeable.
The 93 was also different from all other LT1's with regard to the T56. It had either the M28 with a 3.36 1st gear ratio and 2.73 rear axle, or the M29 with a 2.97 1st gear and a 3.23 rear axle ratio. All other LT1 T56's had a 2.66:1 1st gear, and a 3.42 rear axle ratio. Which tranny you get will affect the rear axle ratio you want. If your A4 has a 2.73 rear axle (GU2 on the build tag), you will not be happy with a 94 and newer T56 and the 2.66 1st gear. You will want to swap the rear axle ratio for something numerically higher.
The 93 VSS sensor is also different on the 93, and there is no skip shift solenoid. Your 93 A4 is the non-electonically shifted 4L60, so you do not have the ECM interface for the electronic shifting, and that simplifies the wiring issues when you swap in the T56.
And, as someone noted in the first response, this post doesn't reall belon in "Appearance", so I'll move it to the "Drivetrain" forum for you.
Biggest overlooked thing in the swap (as fred said) is the rear gear.
you will need Some 3.73 gears, or if you want to have fun get some 4.10 gears.
the stock rear gear is 3.43 if i am not mistaken.
anyone?
anyone?
