fbody 10 bolt in an s10?
Old Dec 12, 2003 | 10:40 AM
Bad AZz Z28's Avatar
Not sure if anyone will know the answer, but I know zero about s10s so I figured it couldnt hurt to ask.
A guy from a local car forum is interested in buying the 10 bolt rear out of my 94 camaro (abs, disc brakes, no traction control). He has a 1990 s10 ex cab.
Is there any way he can make this fit cheaply and work for his truck? I don't know of the length of his current rear end nor its setup, I'm assuming he either has the wheels that came with the truck or he would be willing to change them to whatever makes the rear a better fit. If it can be done, I might have 1 less 10 bolt rear end to deal with so let me know if you have any experience with s10 rears. Thanks.
Mark P.
Old Dec 12, 2003 | 01:30 PM
Mike383LT1's Avatar
10 bolt
i doubt it the s10 is a leaf spring rear the f-body is coil springs you would have some major fabrication to get it to fit spring perches some form of torque arm bracket lower control arm brackets all would need to be fabricated
Old Dec 15, 2003 | 01:48 AM
blownxtreme's Avatar
first your rear is wider then our's, second he would have to weld on a spring perch for the leaf springs to be mounted, you can how ever swap over the disc brakes over to the stock s-10 rears, theres a how to posted on a s-10 forum if you need a link just e mail me, gears and differential should be the same as long as the rear's are the same size, so of us got lucky in the later years with 8.5 rears stock
HectorM52
Jun 23, 2016 08:42 PM
meissen
Jun 1, 2015 07:59 AM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
CaRParts102
Dec 6, 2014 08:45 AM
