Extreme vibration and "clunking"
Old Jun 12, 2009 | 04:08 AM
Spiers's Avatar
So it started as a faint "clicking" noise that decreased with speed that I would barely hear when coming to a stop, then shortly after a clutch dump at a stoplight, a really bad vibration under the car when accellerating. Right after that, on the highway, going ~70 I could just hear a "grinding" noise that made me think the rear end was crying bye bye.
But, I get it home, leave to go to work, and I am hearing extremely loud CLUNKing from under the car along with an extreme vibration, I could not drive over 30mph...sounds and feels as if the whole drivetrain is going to break off from underneath the car and fall out!
I thought maybe U-joints...I pulled the driveshaft and they seem to be perfectly fine, still have grease, no looseness...
-There is none of this at idle or revving when stopped
-Only does it in gear while moving
-If the trans is in nuetral while im moving, it stops and is normal
-If I press in the clutch while moving, it stops and is normal
-The vibration/clunking increases with vehicle speed
-If I touch the gas while moving the vibration is even worse
-The vibration and noise is so bad that the car is not driveable!
Old Jul 5, 2009 | 10:06 AM
corey0224's Avatar
Your going to have to drop your tranny so you can look at your clutch disc, pressure plate and throwout bearing the problem sounds like it's coming from that area. And the worst case senario would be the transmission. I hate drivetrain problems, but hey it comes with the territory. Good luck man...
Old Jul 5, 2009 | 01:29 PM
Spiers's Avatar
It was the rear end. Ring and pinion were broken.
Louey
Pacific
Oct 1, 2015 12:37 AM
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
