What makes a tranny shift hard?
Old Jun 18, 2009 | 09:48 AM
Hal Fisher's Avatar
Beside line pressure, what makes a tranny shift hard? I want to know this because I need a tranny that's set up to handle 400 or so horsepower but I don't want it shifting hard. I don't want those annoying neck snap shifts when just cruising. I know I can control some of it with line pressure but what makes it shift hard when it's built up so I can avoid going too big with that piece?
Hal
Old Jun 18, 2009 | 06:58 PM
redcamaroz28's Avatar
Stiffer accumulator springs can also make it shift harder.
Old Jun 19, 2009 | 01:12 AM
Hal Fisher's Avatar
Thanks!
Hal
Old Jun 19, 2009 | 01:30 AM
Performabuilt's Avatar
Supporting Vendor
if the accums and feeds are set up right you should end up with a reasonable PT shift and agressive at WOT but soft shift and performance are oxymorons
Old Jun 25, 2009 | 10:29 PM
budgetlt1's Avatar
do you have a stall converter? if not, get one. at rpms before it stalls (like cruising) you wont really feel the shift as it is absorbed by the converter when its not locked up. but you will still have the firm shifts at higher rpms.
Old Jul 5, 2009 | 02:23 PM
Hal Fisher's Avatar
Thanks for the good advice, espicially about increasing the stall Budgetlt1. I wasn't considering a stall because the car is only street and a stall is mainly just for the strip (with no pre-burnout and 380 hp I'd just smoke cold tires on the street). I'll try a low stall (2300 to 2500) and see if that gets rid of the increased harshness expected from the Performa's level 2.
Hal
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jason Short
Jan 19, 2015 06:34 PM
tds1213
Nov 27, 2014 12:55 PM
siguy
Nov 27, 2014 10:07 AM
