dont know if this is the right spot but..
Old Jan 29, 2007 | 12:26 AM
  #16
Capn Pete's Avatar
Sorry, I think I'm thinking about the panhard rod, where it bolts to the diff housing on the driver's side?? And I guess both spring perches are behind the centerline of the axles, right? (sorry ... ~1am, brain sleepy ... photographic memory blurry! )
... I know there's gotta be something behind the centerline of the axles to jack up on to put weight on and it should "roll" or "tip" the diff back forward?
Old Jan 29, 2007 | 01:08 AM
  #17
SS RRR's Avatar
Originally Posted by Injuneer
I don't think so. The pinion bearings may suffer excessive loads, but the "pinion angle" relates to the angle the pinion shaft makes with the rest of the drivetrain, not the way the gears mesh.
I do believe you are correct, sir.
Old Jan 29, 2007 | 07:51 AM
  #18
gpss97's Avatar
well i hope i didn't tear anything up then..i mean its not like i was cruisin like that..i was only driving it like 10mph or so not very fast cause the yard was muddy..but i'll check it out today when i mess with it again. thanks
mike
Old Jan 29, 2007 | 02:21 PM
  #19
Loadre's Avatar
Probably was the driveshaft scrapping against the body.
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
ChrisFrez
Sep 9, 2015 06:52 AM
meissen
Aug 11, 2015 06:05 AM
Fastbird93
Jul 11, 2015 04:37 PM
