Difference in the 1994 and 1995 tranny?
Old Feb 9, 2009 | 06:44 PM
extreme79z's Avatar
I have a 95 Z28 and the built tranny in it seems to be giving me a little bit of trouble... So I guess I will have to try something different.
My question is are the 1994 and 1995 transmissions any different? My buddy tells me that he thinks he remembers there being a difference in the two, and I honestly can't find anything on it. I know the 93's are a different bird, but is there a difference from 1994 to 1995 4L60E's?
Thanks for the help.
Old Feb 9, 2009 | 07:43 PM
Performabuilt's Avatar
Supporting Vendor
Yes the 95 has PWM and additional solenoid now you can use a 94 in a 95 simply by adding the solenoid and wiring harness from the 94, To use the 95 in a 94 is a different story and require a valve body mod to work but still easily enough done
Old Feb 10, 2009 | 02:03 AM
extreme79z's Avatar
Any clue as to why my Performabuilt tranny would decide not to engage 1st and then was acting like it was hitting the rev at 4k in second??? I went and parked it and let it cool down... I went out there and cranked it a few hrs ago and it drove up and down the road normally.
Old Feb 10, 2009 | 09:17 AM
Supporting Vendor
Sounds like you went into limp mode, Do you have a stall ? limp mode allows only 2-3 gear manually Once you turn car off this will reset and all will be normal again. Limpcan set for a multitude of reasons but need to scan car first to see what codes are stored.
Old Feb 10, 2009 | 04:31 PM
extreme79z's Avatar
Yes, it has the 3000 stall... I told my buddy that it felt like limp mode, and it didn't let me get it above like 4,000. So I was kinda wondering what it could have possibly done it. Last night I got in it again and cranked it and it drove just like normal. lol I felt like I had got hit with a whole bag of wtf. I will scan it and see if I can pick anything up. Thanks for the info.
Old Feb 10, 2009 | 05:42 PM
Supporting Vendor
Some cars will set a code for shift solenoid B 2-3 with a stall , The PCM i confused by it it may happen occasionally all the time, never .If that's the case the test for that code in programing must be disabled
calaban
May 18, 2020 06:43 PM
Red Hawk 94
Mar 18, 2019 04:03 PM
Sergio
Jan 27, 2016 04:27 PM
joe777107
Dec 1, 2014 09:32 AM
