diferences between tranny's
Old May 19, 2005 | 08:31 AM
fstenuf's Avatar
i'm in great need of a tranny right now. i was wondering if someone could give me the facts on them. i have a 95 z28 and was wondering if a 98-02 style would work? also if its a corvette tranny would that matter?
if anyone has a t-56 i need one asap. or should i just rebuild mine? i really think it'd be worth it to get a new one with a warranty. let me know your guy's thoughts and ideas.
thanks!
Old May 19, 2005 | 09:59 AM
Re: diferences between tranny's
The C5 and C6 T56's will not work at all. They are rear mount in the Corvette, integrated with the differential.
The LS1 T56 isn't going to work as a simple replacement in an LT1 either. The input shaft is longer, and the slave cylinder is mounted on the front cover of the tranny, rather than in the bell housing, and there is no clutch fork, since the LS1 uses a conventional "pusher" type clutch, activated directly by the slave cylinder, rather than the pull-back design used on the LT1.
Old May 19, 2005 | 12:05 PM
taguy001's Avatar
a new one will be quite expensive, they're somewhere around 2k for the factory if i remember correctly. I'd spend the money and do a performance rebuild on it, some places will even give you a warranty on a rebuilt trans.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
