did i mess up the install?
Old Aug 22, 2005 | 09:47 PM
LT1powered94's Avatar
I just put my new engine in. Now my tranny is slipping. It came out with the engine and was removed and installed twice. I think I put too much fluid in there, would that cause slipping? Its a stock a4. It ran well before the pull.
Old Aug 23, 2005 | 11:07 AM
1SlowFormula's Avatar
Re: did i mess up the install?
Over filling the tranny has been known to cause slipping, even after the extra fluid has been removed. Trannys run off of pressure and there are a lot of pressure sensitive parts, by having too much fluid you add a lot more pressure and that can cause damage quickly.
When installing a tranny it is always better to put in a little less then what is required, run it for a few seconds, then top it off using the dipstick...
Nov 18, 2023 07:21 PM
ProjectRacez28
Mar 22, 2015 02:54 PM
Mar 13, 2015 07:15 AM
jasonduaine
Mar 7, 2015 09:44 AM
Mad_Ice
Jul 29, 2002 09:44 PM
