diameter of converters
So, for a street car, 95 lt1 4l60E, what diameter of converter should I be looking for? What is the purpose of having smaller ones or bigger ones? I am trying to figure out my price list right now for my A4 swap. I dont have one to look at as I have an m-6, so I need to know this stuff before I start buying my pile of parts.
Thanks!
Cody
Thanks!
Cody
Re: diameter of converters
How much you looking to spend? I've got a Pro-Built 4L60E with a Edge 9.5" bulletproof converter for sale and I can get rid of the trans mount and a couple other things too since I'm swapping to a TH400. Shoot me a PM if you're interested.
No it's made by Dana at Pro-Built (http://www.700r4l60e.com/). Handled 550+rwhp and 650+rwtq on my car. Has about 8k on it. Getting rid of it because I'm building a bigger motor since I just threw a rod and I'll be past the limitations of the 4L60E so I'm going TH400, and also need a transbrake. 4L60Es are interchangeable between years.
Here's a little primer I wrote on torque converters. It does adress a bit about converter diameter. You shouldn't be concerned about diameter per se but about stall speed and efficiency. Different diameters converters will fit in your bell housing. Why are you swapping in an A4?
http://www.kennedysdynotune.com/Torq...ter%20Tech.htm
Rich
Edit: when I read it, I guess I didn't adress size per se. But as I said above, "size doesn't count". It's what the converdoes, not what size it is. In general, the higher the stall, the smaller the converter though.
Rich
becuase I want to drag alot, and autos are more consistent. Plus to rebuild my stick and buy the street twin is too much money. I can get this done for like two grand, and its alot more fun to just drive it. Plus the auto is a little gentler on my stock rear until I can afford a dana 60.
Aug 5, 2015 08:35 AM
detroitmuscle
Jul 31, 2015 04:21 AM
