cracked piston
Old Apr 15, 2013 | 08:36 PM
Chet1185's Avatar
cracked piston
Would a cracked piston in the input drum cause no 3/4.
Just tore my Trans apart and rebuilt it, piston was cracked pretty good and the 3/4 clutches were not burnt but the first two clutches in the bottom of the input drum were bare metal no fiber on them, they were also conned really bad.
Just installed molded pistons, so hopefully it won't happen again.
Posted from Camaroz28.com App for Android
Old Apr 16, 2013 | 07:48 AM
12SCNDZ's Avatar
Re: cracked piston
A cracked piston will cause burnt forwards and possible no forward movement. If you had 1st and 2nd, the forward piston isn't what caused your no 3-4. You have another issue somewhere.
Frank
Old Apr 16, 2013 | 08:48 AM
Chet1185's Avatar
Ok....air checked everything and it all works
Old Apr 16, 2013 | 08:57 AM
Chet1185's Avatar
What else would cause no 3/4? The valve body is now in another Trans I built and it works great.
magman
Apr 15, 2016 03:08 AM
David Dempsey
Mar 12, 2016 12:42 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
