Cost for A4 to M6 conversion?
Old Jan 7, 2007 | 07:31 PM
CrazyLT1's Avatar
Not taking into consideration any parts. How much would be a fair cost for labor to do a full A4 to M6 conversion?
I am trying to decide whether to build my 4l60e for the 550 RWHP it is putting down or to convert to a 6-speed with a solid clutch. But if I go 6-speed, I will probably not want to do the labor myself - so how much do you guys think the labor cost for this would be?....
Old Jan 8, 2007 | 03:53 AM
30thTA0525's Avatar
labor= rediculous.. if you can install an auto trans then you can do the swap.. its a pretty easy project.. not too mention rewarding if you want a manual.. cant beat getting in for the first time too row the gears haha
Old Jan 8, 2007 | 12:14 PM
Wrong forum.... LT1/LT4 Engine Tech is not the place for tranny questions.
Moving......
Old Jan 8, 2007 | 02:01 PM
arcticz28the383's Avatar
Cost me about $2300 total. $1500 for a t56, $600 for spec 3 and fizanda flywheel and $200 for conversion parts. Im sure there are odds and ends im fogetting about tho.
Old Jan 8, 2007 | 02:07 PM
Capn Pete's Avatar
Agreed!
My 4L60E blew in July of this past year ('06 ... holy crap, it's '07 now?!! ) ... anyway, by the time I tracked down a tranny w/parts, I had it in my garage on a Friday, and by the Sunday night, the car was mobile . Before it arrived, I had the auto pulled, and everything associated with it (shifter, pedals, flywheel, etc.). Using a couple of the independent online "guides", I already had the hole cut in the floor for the shifter, so when the tranny showed up, I just had to install the pedals, and then start bolting things up ...
... I am NOT a mechanic by any means (only learned what I could from my Dad who IS a mechanic) but aside from having a friend of mine provide physical "assistance" (slugging out/in the 2 transmissions) I did all the technical work myself . I think I put about ~24 hrs work into it, and I work slow. I've read where guys have everything done in about ~12 hrs!!
But there ya go, if you want to factor what labor would "cost", count on at least ~12 hrs, maybe more, depending on the skill of whomever is doing the work .
Novo
Jun 14, 2016 02:58 AM
Sep 11, 2015 09:44 AM
tdigger9899
Sep 7, 2015 10:56 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
