?conversion?
Old Apr 28, 2006 | 08:12 PM
jamieSS's Avatar
Question ?conversion?
How expensive would it be to switch from a automatic to 6 speed transmission? What parts would i need to buy besides the transmission?
Old Apr 28, 2006 | 08:18 PM
RacingTiger04's Avatar
Re: ?conversion?
this comes up a lot.. do a search on 6 speed conversion.. the conversion parts are usual around $1500 for everything and then whatever in labor if u have somoene else do it.. the search will show up a link to a site tha thas a full guide and parts list of everything you will need, but im just too lazy to search it right now .
Old Apr 29, 2006 | 12:53 AM
jamieSS's Avatar
?conversion?
thank you alot! i appreciate it
Old Apr 29, 2006 | 05:28 AM
rskrause's Avatar
Moderator
Re: ?conversion?
Besides the tranny you will need a bellhousing, pedal assembly, shifter, clutch hydraulics (master and slave cylinders and lines) and a clutch assembly. For the interior you need a new console and a shift lever boot. You will also need a new tranny crossmember.
Rich
Old Apr 29, 2006 | 01:05 PM
jamieSS's Avatar
Re: ?conversion?
For the money put in to buying the conversion, is it worth it?
Old Apr 29, 2006 | 01:57 PM
94EvilZ28's Avatar
Re: ?conversion?
HELL YAH....i love my car so much more now...way worth it...rather than have you do a search...heres this man...if you got any questions...shoot me a message...
http://www.afrashteh.com/tranny_pics/T56.htm
Youre lucky if you get a full kit with EVERYTHING for 1500. Plan for 2500-ish...just to be safe...I wound up spending 1500 for the kit and 1200ish for the clutch and everything...but I am particular about things...
Good luck and have fun...it is worth it.
Old Apr 29, 2006 | 07:31 PM
paul463's Avatar
Re: ?conversion?
I recently did the conversion and could not be happier with the results. The car is lots more fun to drive. It is an involved process to do it right but from the looks of your car you see things through. Good luck with your decision.
Old Apr 29, 2006 | 08:17 PM
Re: ?conversion?
i really need to save that link somewhere for myself .. but i guess i got lucky on my kit then i got EVERYTHING for 1000 but then deicded to go ahead and do a new clutch pp and re-surface flywheel so totaled up at 1700 though im not sure now cause the place i got everything from has lost the crossmember and has to find me another one now *sigh*..
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
