Confused - Transmission Codes
Old Sep 21, 2009 | 05:14 PM
camarosource's Avatar
Could someone please shed some light on this confusion..
Seems Chevrolet liked to confuse people with multiple RPO codes for transmissions.
my understanding is that the MX0 is a RPO used to refer that one selected an automatic 4 speed transmissions. However the 2010 Camaro seems to use this as a Generic RPO for the Auto 6?
Upon further documentation (Restoration kits, Books, Magazines, and online sources) there are even more RPO codes for various Transmissions throughout the year referring to the same transmissions..
For example the following shows reference of two RPO codes for the same transmission
Example:
5-speed Manual M49 & MM5
4-speed Auto MD8 & MX0
6-speed Manual M28 & MN6 (Same MN6)
6-speed Manual M29 & MN6 (Same MN6)
MB1 & MM5
M39 & MM5
MK6 & MM5
And many others thought the years..
Going by this it SEEMS to indicate that :
- MM5 was the code to refer that a Manual 5-speed had been selected
- MN6 was the code to refer that an Automatic 6-speed had been selected
But other years become more puzzling.
1. Which of these would show up on your RPO decal? Both M49 and MM5 ?
Referring to the restoration kits make it even worse because of one part they list for example M49 as the transmission for a given engine, and yet other pages mentioning the same indicate MM5 then an RPO list show the transmission as being M49, then another RPO list somewhere else might show it being M49.
2. How exactly can you easily understand what the transmission codes refer to? (Whether they are those above, or others from other years as there are more that I have yet to mention) How do you know which is for the "Denoted selection of a TYPE of tranny (i.e.. a 5-speed manual)" and which refers to the ACTUAL SPECIFIC transmission?
Thanks,
Paul
Old Sep 24, 2009 | 02:56 PM
Crazystars's Avatar
Confused Transmission Codes
if my automatic t/a lt1 96 only goes into 1st gear and 2nd gear and just when its about to go into 3rd ..it revs up real high 4-5000 rpms before it catch 3rd gear ..now keep in mind im only going about 30 miles per hr at the time it goes into 3rd gear ...then after that
3rd shift ..its just rev real high but wont change gears ...i put transmission fluid in it ..because it was extremely low..a mechanic told me that it could b a silenoid throwing bad codes or it could be that the connector on the tranny is dirty ...what do u all think it might b..and it only has 70k mile on the tranny ....if that help any
jackpawt883
Feb 26, 2015 09:04 PM
Jul 4, 2005 05:00 PM
RedIrocZ-28
Aug 20, 2002 01:11 PM
91Bird305
Aug 5, 2002 01:39 PM
squirrels
Jul 13, 2002 01:58 AM
