complete my bottom end
Old Mar 21, 2010 | 12:39 AM
cutlassryder's Avatar
First off I have a 1988 olds cutlass supreme. It has the following.
350 block .60 over.
comp magnum cam .501 exhaust lift
96 chevy vortec heads. worked to hold up to a .650 lift cam
600 edelbrock carb
my mechanic over reved this engine so i put new heads (above)
now engine knocks and I know i spun a bearing.
3:73 gears 29 inch tires
limited slip possy rear end
350 trans with 2800-3000 stall.
eagle steel crank that I will have turned.
im shooting for 11:1 compression, or 93 octane pump gas for this setup
HELP what pistons, rods should i get to match this equation. i want at least 500 hp. thats what my crank is rated at. will be used for street, and strip.
Old Mar 21, 2010 | 02:27 AM
mr_happy's Avatar
Flattop Forged pistons and h-beam rods....
Old Mar 21, 2010 | 03:46 PM
what length rods?
Old Mar 23, 2010 | 05:58 PM
You're in the wrong forum.... "Drivetrain" is for tranny, driveshaft, rear axle, etc. Not for the engine "bottom end".
Jun 6, 2015 08:27 AM
alphaauto
Feb 5, 2015 05:25 PM
Killer94z
Jan 13, 2015 12:06 PM
Collector Car
Jan 5, 2015 10:58 AM
