Clutch won't disengage
Guys,
Here's the scenerio:
If the car's engine is turned off, I can put it into gear, start the car and the car moves. If I pull it out of gear into neutral and then try to put into another gear, it won't get into any gear. The only time I can get it into gear is when I turn the car off and put it into gear. What do you suspect is the problem. I have the LS1 and T56 package.
Thanks.
Thanks.
ducttape1975
Jul 10, 2015 06:29 PM
