Is this clutch useable or worn out?
Old Sep 6, 2007 | 02:08 AM
Explodinggopher's Avatar
Had to pull the motor for a spun cam bearing, not a lot of money to spend after the machine shop bills, so i know the clutch was replaced not long ago, I think its a LT4 PP from the looks of it with a stock clutch disk, it chatters a bit but has never slipped in any gear, i had the flywheel resurfaced while its out too. Is this clutch too worn out to put back in? how about the pressure plate? Anyone know what brand this is for sure? Mods are in sig. Maybe just a new (is that stock) clutch disk from autozone? resurface the LT4 PP? Thx.
Old Sep 7, 2007 | 02:27 PM
izzyz28's Avatar
That looks like a stock disc to me. If you're sure the flywheel and PP are in good shape, I would recommend tossing that disc and buying a SPEC stage 3 disc or maybe a McLeod or other brand disc. I think they cost anywhere from ~$99-$170.
Old Sep 7, 2007 | 02:34 PM
95LT1conv's Avatar
If it is apart, might as well change it now.
Old Sep 7, 2007 | 04:01 PM
arcticz28the383's Avatar
Dont spec clutches use a pressure plate that grips "tighter"? I would just buy a new clutch assembly if I had mine all apart.
Old Sep 7, 2007 | 04:30 PM
dangalla's Avatar
no.,.. valeo pp same as lt4
it would prolly be a good idea to just grab a mcleod street single for the 175 they cost, and throw it in while it will be so easy
Old Sep 8, 2007 | 08:32 PM
you guys think the PP looks good still, looks like some glazing not much, and like i said it never slipped no matter how hard i drove it.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
