Clutch recommenation
Old Apr 26, 2007 | 08:56 AM
blackz28's Avatar
I have a bottle-fed '95 LT1, and it's finally in need for a new clutch (still on orginal clutch with 127k).
I've narrowed it to a centerforce dual friction or a Spec stage 2. Any of you LT1 guy's have good or bad experience with either or any other around $500?
Old Apr 26, 2007 | 11:05 AM
ConElite's Avatar
Im stock, and Im running the SPEC S1 and it grips hard. I dont get any Clutch Slip whats so ever. I have run it on the track and it grips Fine. On the road It chatters a little but I think thats b/c the Clutch plate is warped. Other than that its a great Clutch. An S2 from SPEC should be good for you. The D/F Centerforce is pretty expensive but they are very good. I'd say for the best bang for the buck, SPEC is the way to go.
Old Apr 26, 2007 | 01:11 PM
blackz28's Avatar
Thanks for the feedback
Old Apr 26, 2007 | 02:12 PM
FormulaFirebird's Avatar
i have a 94 LT1 and my clutch is starting to slip also... i have been researching clutches for awhile and have talked to/read a lot of opinions. well today i ordered a centerforce DF from Jegs for $581. after calling a local perf. shop and hearing there horror stories about spec's coming back over and over i went with the DF. between the two i would play it safe and get the centerforce. Spec seems to be to much of a luck of the draw kinda thing.
Old Apr 26, 2007 | 03:12 PM
ConElite's Avatar
Honestly Bro, You will hear the same thing about McLoed or DF clutches. Depends on who you talk to.
Old Apr 27, 2007 | 09:24 AM
well what also affected my decision was i installed a DF myself in a friends WS6 and we havn't had problems with his clutch ever. been about a year now and he drives it hard.
Old Apr 29, 2007 | 01:03 PM
bt96ss's Avatar
I went with the stage 3 spec and their steel flywheel. Everything went together smooth. Your mods are very similar to mine. I spray it with 150 shot a few times a week. It's been in there a year now with none of the other issues some claim to have. It grips very good and holds fine on the bottle. Just take your time with the install and I highly recommend their flywheel at the same time. I got it when it was on sale at Tbyrne.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
