Clutch pedal not always coming back up on '02 SS, need diagnosis
We have an '02 SS with under 17,000 miles, and the clutch pedal is not always coming up when depressed. The car is 100% factory original and unmodified.
It ONLY happens when the car is stopped at a red light or stop sign and the pedal is held down for a period of time. It never happens when the car is moving and shifting through the gears.
When it happens, the clutch pedal has to be lifted back up by putting your foot underneath it and pulling it up.
The car isn't raced and doesn't live a hard life at all.
From your experience... does this sound like a hydraulic slave cylinder problem, or does it sound like a mechanical release fork/release bearing problem?
Also, the clutch fluid is the fluid that came in the car when purchased November 2001. The level is proper, it isn't leaking, and the color/appearance of the fluid seems fine though it does have a bit of an oily look to the surface.
The clutch isn't making any unusual sounds. It still sounds like a brand new car.
I just checked the clutch fluid a little bit ago after doing some research to see what color it is supposed to be, and it is absolutely filthy. It's dark brown with stuff floating in it. I wonder if changing that will correct the entire problem...
The slave cylinder was around $100.
Time involved depends on your experience and tools.
The work involved is dropping the tranny, exchanging the part, installing the tranny.
Not trying to be wishy-washy, but we ended up doing it out in the country with all the tools an hour away. Any time we needed something we did not have, it meant a road trip. And we had never dropped a T56 before. So it took a couple of days, all told.
The next time, it will probably only take us 4-6 hours.
I bet it's just because the fluid is absolutely filthy. I hope at least...
We ended up having the fluid changed AND the clutch, which was very expensive. There was a lot of clutch dust on the starter, so it was evident that the clutch was wearing out.
We're not real sure why the clutch was so badly worn out considering nobody rides the clutch. We think maybe somebody at a dealership had a little too much fun driving the car after an oil change...
Thanks for the reply. I am going to change my fluid first and see how it responds. Someone else told me about the following link which I found extremely informative. http://www.rangeracceleration.com/Clutch_Care.html
Dave
Dave
I saw that link too. Somebody told me about a drill mod that fixes a sticky clutch pedal issue on Camaros, but since I don't own a drill, I never read about it. If I remember the summary, it basically said that the hole for something or other wasn't big enough and if you drill it a little bigger, it fixes the problem.
You might check the underside of your car with a very bright light and see if you have clutch dust all over your starter. Your starter is located on the passenger side of the car on the side of the transmission very close to the catalytic converter if your car is an '02. You'd have to get your entire head under the car to see it, I don't think you could just look under your car and see it.
Here's a pic, keep me updated and what you find.
2 dirty pics, 1 cleaner pic after the guy changed the clutch
Is it just me or does the transmission look like it is mounted funny now?!?! Or is it mounted funny from him checking the clutch earlier...?!?!
