Is the clutch pedal lower than the brake pedal?
Old May 19, 2005 | 03:05 PM
  #16
speed_demon24's Avatar
Re: Is the clutch pedal lower than the brake pedal?
I bought a Ram adjustable master cylinder and now my clutch pedal is higher than the brake pedal, so power shifting is a breeze.
Old May 19, 2005 | 03:06 PM
  #17
madwolf's Avatar
Where did you buy it from and how much was it?
Thanks.
Old May 19, 2005 | 04:24 PM
  #18
http://www.neweraperformanceparts.com/default.asp?S=503&A=E&PKV=ram510|0 (copy paste the whole link)
It's listed for an ls1 but the LT1 and LS1 use the same master cylinder.
Old May 19, 2005 | 04:27 PM
  #19
madwolf's Avatar
Thanks. Does this come as a full kit like the stock one (it doesn't look like it) or do you have to connect it to the stock one? And then re-bleed?
Old May 19, 2005 | 09:06 PM
  #20
It's just the master cylinder, you have to connect it to the slave, and re-bleed it.
Old May 19, 2005 | 09:14 PM
  #21
Alvin@pcmforless.com's Avatar
Mine is this way too, I corrected most of it by getting the bolt holes for the slave cylindar drilled more in the correct spot.. hard to explain but if they are off the slave cylindar will not have full travel.
Its about on par with the brake pedal now.
CGM2010CAMARO
Apr 7, 2015 07:44 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 31, 2015 07:29 PM
HectorM52
Jan 30, 2015 11:08 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
