Clutch master gone?
Old May 15, 2007 | 05:12 PM
phoenix1987's Avatar
Clutch master gone?
I was driving the other day, pushed in the clutch and gave it a little rev. My car pops out of gear and the pedal goes to the floor! Try as I might, I can't get the car into gear while it is running. I can shift into all of the gears while the car is off however. I have heard some bad things about the Centerforce dual friction clutch, but I have only put about 400 miles on my brand new clutch, master and slave.
I have yet to bleed the system, which I will get done this week. My master is a GM which was prebled, do you still have to bleed the system when hooking up a brand new slave? Anyone have any tips or ideas?
I can drive the car if I put it in gear then start it (which I had to do to get it home) I got on it a little to see how it would react and it went like therre was nothing wrong.
Old May 18, 2007 | 01:00 PM
hotrod18_69's Avatar
Yes you should have bleed it after you put it in.. Trying bleeding it now and see what happens.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
