Clutch fork WILL NOT engage
Old Nov 30, 2004 | 04:56 PM
Kurt Crosbie's Avatar
No matter what I do, it will not go in. I move it every which way and it won't go in. This is all I have to do to get the car to run. How are you supposed to do it?
Do I have to pull the tranny back off, engage the fork, then slide the tranny back on?
Old Nov 30, 2004 | 09:40 PM
GreenDemon's Avatar
Re: Clutch fork WILL NOT engage
I think when I did my swap I had it on the T/O bearing before I put the transmission in. But I don't think there's any reason you couldn't slide it on with the tranny on. Have you tried loosening the bolt that holds it in for some more room?
Old Nov 30, 2004 | 10:18 PM
MISSION: Accomplished
I unbolted the crossmember from the frame and backed the tranny out about 1". I was able to leave the driveshaft and torque arm connected. That gave me enough room the see the throwout bearing and slide the fork on over it and engage it and slide the tranny right back on. Took about 10 minutes.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
