clutch fork t stud
Old Jan 16, 2007 | 06:54 PM
reaper1990's Avatar
clutch fork t stud
hey guys, I need a little help here. I've got a 90 model gta I'm doing a 6 speed swap into and I can't seem to find the t stud I need. I bought a new clutch fork and bolt from the dealer but they can't seem to get the t stud or pivot that the fork rides on. The counter man says the parts I have are all that's listed. Can anybody help me? The tranny by the way is a 95 so that's what year I got the fork for. Also I have a set of pedals from an 89 gta and the hydraulics as well. My understanding is that the pedals will work but the hydraulic line will be to short. Can I simply replace the line with a custom high pressure line? I have a local place that makes lines up to 20000 psi. I'd sure appreciate any help I can get
Old Jan 16, 2007 | 10:40 PM
You should be able to get replacement parts from D+D or Keisler.
http://www.ddperformance.com/
http://www.keislerauto.com/
Not clear what "hydraulics" you bought...... from a 95 LT1 or from an 89 GTA??
Old Jan 16, 2007 | 11:02 PM
mdacton's Avatar
if you are trying to run the gta master and the 95 lt1 slave cyl...and get your line made etc. How you going to bleed it?
Old Jan 17, 2007 | 03:08 PM
reaper1990's Avatar
thanks for the replys guys. I finally found a place online called www.autogear.net which had the pivot for $0.51 and a clutch fork for $30.66. I wish I saw these guys day before yesterday becuase the dealer charged me a$104.00 for the fork. I got the hydraulics out of a 88 camaro. I can have a custom line made no priblem but what about bleeding? Is there no bleed screw on that year? I bought them online so I haven't seen them yet.
Old Jan 17, 2007 | 03:23 PM
reaper1990's Avatar
I forgot to add I'll be using the complete 3rd gen hydraulic system except for a new line so bleeding shouldn't be a problem shouldn't be a problem should it?
Old Jan 17, 2007 | 11:11 PM
Is the slave cylinder from an 88 Camaro going to work with the unique "pullback" design of the LT1 clutch?
Old Jan 18, 2007 | 07:01 AM
mdacton's Avatar
i'm not sure...it may, but i don't think they have a bleeder
Old Jan 18, 2007 | 10:50 AM
reaper1990's Avatar
Well now, you guys may have me stumped there. I've been reading up both on this site and thirdgen .org and I think the thirdgen slave should work. I'll know for sure in a couple of days. I've also been told that that to bleed the slave there is an allen screw to open or you can point the rod at the ground and slowly pump the air out of the slave and into the master resevoir, bleeding air out that way.
Old Jan 18, 2007 | 02:41 PM
OBE1 95Z28's Avatar
Be sure to add loctite to the threads of the hold down bolt for the T stud; mine worked it's way loose over time
Old Jan 18, 2007 | 06:38 PM
mdacton's Avatar
if it does have the allen screw then great you can bleed it that way....it won't work by pumping the slave b/c air can't get past the piston in the master....just wait to see what you get, its a pretty popular swap
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
