Which Clutch?
Old Nov 19, 2004 | 09:55 AM
UltraZLS1's Avatar
Which Clutch?
After the winter my car will be making between 380-400 rwhp.(Cam, true duals,LS6,Bolt-ons, Dyno tune)
It will also have 3.73 gears and an eaton posi.
So it will only be a matter of time before my stocker goes out.
What is a good all around kit for a daily driver with the power I am making? probably go to the track 2 or 3 times in a year.
Needs to work with stock hydraulics and flywheel.
thanks
Old Nov 22, 2004 | 10:32 AM
CamaroBoy96Z28's Avatar
Re: Which Clutch?
I use a SPEC stage II and plan to making that power as well plus it drives real nice. Either a Stage II or III should do. While you're at it if you havent already, upgrade to the 01-02 hydraulics while the tranny's out.
Old Nov 22, 2004 | 12:36 PM
rskrause's Avatar
Moderator
Re: Which Clutch?
Do a search to get a good sample of feedback on clutches.
Rich
Old Nov 22, 2004 | 05:57 PM
CrippleFightin's Avatar
Re: Which Clutch?
I just installed a Spec stage 3 on my car thats making about 374/381 to the wheels. I have driven it about 80 miles with this clutch so i havent been able to stomp on it yet, but shifting is alot smoother and I like the clutch so far. Driveability is almost the same as stock as well.
Old Nov 22, 2004 | 10:39 PM
UltraZLS1's Avatar
Re: Which Clutch?
Cool...do I really need to update my hydraulics?
How long can I expect my stock clutch to last?...it has 85k on it...but still feals great.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
