clutch
Old Mar 13, 2004 | 11:59 AM
CamaroZ28LT1's Avatar
clutch
ok im putting a used clutch in my 1997 z28 and im trying to get the center consel out but its loose and ready to go but im having trouble getting it over the E-brake. Now do i need to remove it and how can i move it out over the e-brake? and if i dont have to remove it how do i work around it? also does anyone have the trouque specications for the bolts. I'v been to a website that shows how to remove the clutch and my dad is saying that i need to remove the hydryic??? line and drain transmission fluid to do this i need some help so anyone out that knows how to do this the right way please help me thanks josh
Old Mar 13, 2004 | 12:15 PM
chpmnsws6's Avatar
pull the e-brake up further and its gonna be a tight sqeeze but it will come. it takes some muscle to get the ebrake up all the way but it must be done
Old Mar 13, 2004 | 06:33 PM
Camaro97USAF's Avatar
If ya stick a long screwdriver down where the ratchet wheel thing hits that gear ( I know, i shouldn't use such technical terms) the e brake will swing right up without making it difficult. Just lift up on the ratchet thing.
Old Mar 14, 2004 | 11:08 PM
Red96Lt1's Avatar
If you have the stock shifter, just take the stick off to pull the tranny.
Old Mar 15, 2004 | 10:14 AM
clutch
ok i have the center piece out now i took the four bolts off the shifter, now what do i do from there do i pull the shifter out then get underneith the car or get under the work with the drive shaft?
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
