TH400 Gearing (2.75 vs. 2.50)
Old Mar 15, 2004 | 08:06 AM
Wicked's Avatar
I currently have a 2.75 first gear in my TH400, but the guy who is going to be doing my rebuild told me I should go with a 2.50 first gear.
What I'm wanting to know is if this change is going to negatively effect my 1/4 mile ET's. Obviously, the car wont launch quite has hard off the line, but it will also be in 1st gear longer.
If there will be no real difference I would assume the 2.50, so the car will launch a little easier when I put the full nitrous shot on it.
Thanks,
Jason
Old Mar 15, 2004 | 08:13 AM
OldSStroker's Avatar
This is probably a good "Driveline" topic. The trans gurus hang out there.
The 2.75 must be an aftermarket gearset, right? If it needs replacement it's probably expensive. Stock was 2.48, I believe.
Wasn't the 350 2.50 first?
You'll see about 5 mph more in first as you said. If traction is any problem now (2.75s), it might help until you squeeze the juice to it.
My guess is 2.48s might be stronger unless 2.75s were premium material.
My $.02
Old Mar 15, 2004 | 10:53 AM
kmook's Avatar
Advanced Tech Moderator
Transfering to the Drivetrain Forum.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
james007moore
Jan 1, 2016 01:14 PM
