clutch
Old Feb 26, 2004 | 08:56 AM
JASON5's Avatar
clutch
is hay's clutch a good clutch for ls1 f-body, if it is where can i find the cheapest place to get one
my dad told me he had one in his 427 69 camaro race car, and it worked well, thats why i asked thanks
Old Feb 29, 2004 | 03:18 PM
94CamaroZ28's Avatar
Best deal going to replace an LS1 clutch is the Z06 package from Scoggins-Dickey (www.sdpc2000.com) for 325. Includes a new flywheel, clutch disk, and pressure plate. PP/Disk are Vette Z06 parts; hold better than stock at a great price.
If cost were no object, perhaps the best clutch on the market for an LS1 is the McLeod Street Twin. It's a two disk setup, holds like a dream, but not much more pedal effort than stock, and also not chattery like some of the cheap clutches with extreme friction material. Cost with a new adjustable master cylinder, PP, and disk is around 1000 to 1500 depending on source, and add about 300 more for a new flywheel and new slave cylinder. This setup HAS been known to eat stock rear ends if you simply shift hard into second; it is a very very grippy clutch.
Either way, if your LS1 is 97-00, you'll also want to upgrade the slave cylinder, 120 from Scoggins Dickey. )1 and up already have the upgraded slave. Want to know why you should do this, do a search, it's been discussed many times.
Any LS1 benefits from doing the drill mod... see www.installuniversity.com.
I'd stay away from the Hayes. Proabably costs more than the Z06 anyway.
The above refers to LS1 ONLY, not to LT1.
Old Jan 7, 2005 | 09:22 AM
lt1camaroman93's Avatar
Re: clutch
sorry to dig up from the dead, but is the slave they sell for the 98-02 f-body the upgraded one or the stock one? My clutch is on its last leg and i need to order some parts quick
Old Feb 4, 2005 | 04:35 PM
MysticTeal 95 V6's Avatar
Re: clutch
Any new slave cylinder that you order from a parts store will be the updated version.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
